So I started considering it after seeing what speeds and voltage it runs at and what others were able to get. So while I haven't ran cpu-z or prime95 l did notice that in the mw3 benchmark it was running at 4030 mHz and getting up to 1.43v, I know it won’t run at 4.2GHz at all times. Temps were 50-55°C. l've seen an average around 50° in-game. Idle temps between 35-37°C. Should I manually overclock it? Right now I have ryzen master on default settings and in bios the game boost is off I believe. Not really thinking about getting more fps but maybe lower voltage less heat and that's always better. Should I at least try it?
Specs are -
Ryzen 53600
Msi x570
Corsair h150i cooler
2070 super
Corsair hx1000i
Edit- so I just ran cinebench and on multicore it got up to 69-71°C and was running about 1.37-38v. On single core it’s running at 52-54°C and voltage 1.42-45v. On single core clock speeds do seem to vary from ryzen master to hwmonitor. Ryzen master shows no higher than 3600mHz while hwmonitor is at 4100-4150mHz.
Single core score - 1178pts
Multi core score - 8560pts
Specs are -
Ryzen 53600
Msi x570
2070 super
Corsair hx1000i
