I've recently got me a RX 6800 XT. My max frequency in Adrenalin is 2494MHz. My min frequency is set to the default 500MHz. My undervolt setting is currently at 1050mVa. Everything runs fine and smooth, playing Shadow of Tomb Raider on 4k, high settings, with constant 60 fps, no framedrops or anything. I don't intend to play on ultra settings nor to go above 60fps. Should I then care about setting my min frequency to 100MHz below my max frequency? Or is all that I will get by doing so more power consumption, higher temperatures and louder fans? Which option is better for my GPU's life span? Is it more stressful for the GPU to work with occasional MHz drops, or is it more stressful to keep a constant frequency but at the cost of drawing more power and running hotter? I'd say that more power and higher temps are worse than oscillating frequencies. Am I right?
