Should I Switch the intake stock fan or not? Mini Itx build
Jul 10, 2018
I'm using Lian Li's PC TU200 , a mini build with i7-8700, Gtx 1060 6g. The case only has a 140mm intake fan in the front. I was wondering if I'm planning on gaming, should I replace the case fan with another fan, or just use the stock one that came with the pc?
Jul 10, 2018
I'm planning to switch the cpu cooler to the Noctua NH-L9x65. I'm only not sure with the 140mm intake fan that's located in front of the pc case. I'm planning on gaming with the PC, so I'm hoping there's a fan that can decrease the heat of the gpu and maybe other components.
