Question Should I "Unlock Voltage Control" in MSI Afterburner in order to use Voltage/Frequency curve?
If you try viewing the voltage frequency curve without unlocking the voltage control then what happens?
Is there an error message or some pop-up window indicating that the voltage control needs to be unlocked?
Other than just being able to view the Voltage/Frequency curve is there some specific reason for doing so?
Concern being that the curve results may not be directly helpful and even lead to problems if misunderstood or misconfigured.
More information needed.
