[SOLVED] Should I upgrade from stock cooler to Liquid cooler?
Saurabh251
67
Hey guys,
I have built my pc recently,
Asrock B365 hdv motherboard
I3 9100F
8GB CORSAIR DDR4 RAM
ASUS GTX 1660 SUPER
120gb ssd which is enough for me
500gb hard drive
WITH Antec 550 w Power supply..
https://www.amazon.in/dp/B07TZX5BGN/ref=cm_sw_r_cp_apa_i_C5SfFb2ZSYAE6
Stock cooler doing good job right now BUT still I'm thinking to upgrade for future reference etc...
I have some money left to spend on pc :)
So please tell me its worth to upgrade?
Karadjgne
Ambassador
Liquid or air is the same thing essentially, until you get into the 280mm/360mm aios. Those only have the advantage in capacity over big air.
Corsair H60 = CoolerMaster Hyper212 Evo. Same performance, almost identical curves. Hyper212 costs $35, H60 costs $80. Only reason to buy the H60 is physical limitations of the case. That works for all size ranges.
For that price range, I'd rather have a beQuiet Shadow Rock TF2 at $70. Considerably better than the H60, lower profile than the Hyper212 and still downdraft style.
Reactions: Saurabh251
Ziadul87
481
48
740
21
Upgrading from 8gb to 16gb ram, is it worth?
Games like FarCry5 are already coming out with minimum recommendation of 8GB RAM. And some are already recommending 16GB to be played comfortably.
So, getting a 16GB RAM is worth the upgrade.
Btw, ram pairing is troublesome (if you're unlucky, they won't work well together).
Get a 2×8GB kit. They come paired directly from the manufacturer.
