Should I upgrade my graphics card first or my CPU ?
Nate_739
24
Hey guys , I'm thinking of upgrading this PC since I don't think it's gonna run all these upcoming games (Dead Rising 3, Evil Within, Witcher 3) I'm going to upgrade both CPU and graphics card, thought I don't enough budget for both right now.
My specs right now:
CPU - AMD A6-6400K 3.9GHz
Mobo - MSI A55M-E33 FM2+
RAM - 4GB DDR3
GPU - Gigabyte Radeon R7 250 1GB GDDR5
Storage - 1TB HDD
PSU - 400w PSU that came with the case I bought
Thinking of upgrading my CPU to FX 6300 (Buying a new mobo too) and upgrading my GPU to R7 270. What do you guys think ? Should I get CPU first or GPU ?
APU's are really rather weak in the desktop market. In a laptop they're competitive, but in a desktop it's bottom of the barrel.
That said I have no clue as to what your budget is here. If I had to chip in with a suggestion here it would be go with an LGA 1150 i3, and an H97 motherboard. LGA 1150 socket will enable a good upgrade path later on, and be better overall than any APU.
So I should just upgrade my CPU to A10-6800k instead of getting a FX 6300 and a AM2 mobo ?
Yes, will make a big difference.
