Hey all,
I have noticed that my machine is having problems powering up external devices that have hard drives in them, but what puzzles me is that this wasn't the case back then.
I usually plug my external hard drive and iPod classic (the 120gb one) into my machine in the past with no problems but now i just hear ticking sounds which I think means that my machine can't provide enough power to the components.
I then tried the following:
- Unplugged 2 120mm fans that have LEDs in them
- Unplugged my LED light thing that has 3 LEDs in them
- Set my third 120mm fan to the lowest wattage via fan controller
Then I plugged my external hard drive but it still won't work continously, but at least it was detecting it. As for my iPod it was seeing it in device manager and I was able to add files into it but the connection to the device was intermittent.
And then one day I was messing around with it again I unplugged the video card but left the fans and other components plugged in but it still can't detect my external hard drive.
I am starting to blame two things now, either the PSU or the MOBO.
I use a HEC Raptor 500w PSU. Motherboard is an ASUS M4A785TD-V EVO (AM3).
I used this calculator to calculate my wattage consumptions.
Here are the values that I got from the calculator:
I set the capacitor aging variable to 20% because the PSU is 4 years old, this is based on the recommendation of the calculator on it's footnote.
Thanks for any input guys.
