Wow. That's a Delta 80mm case fan, you'd usually find them in server type cases or old AT cases as they'll top out @3600± rpm. Bring earmuffs, those puppies get loud! Great fan, Delta makes probably the best of all the high speed fans, but it's not really applicable to a home use pc and any sense of peacefulness or tranquility. Most definitely will not be an issue using it on a cpu heatsink, it's got all kinds of cfm + static pressure at those rpms, and 80mm is quite a jump in ability over the stock radial cooler fan.
I don't see a problem using it
If you do opt to shop for a quieter cooler, research your case specs. Many tower style coolers end up being too tall for many cases, especially the 140mm varients, but even a CM...
