J Jeeperii Reputable Feb 10, 2016 74 0 4,630 Feb 14, 2016 #1 I'm going to build a budget gaming pc and wanted to use hybrid drives, are they good?
Solution USAFRet Feb 15, 2016 Jeeperii : Only the hybrid drive and it will be used for casual gaming. Well...they're not terrible. I personally wouldn't, but you can if you want.
USAFRet Titan Moderator Mar 16, 2013 179,751 22,089 184,590 Feb 14, 2016 #2 Jeeperii : I'm going to build a budget gaming pc and wanted to use hybrid drives, are they good? This depends. What other drives will be in the system, and what will this be used for? Upvote 0 Downvote
J Jeeperii Reputable Feb 10, 2016 74 0 4,630 Feb 15, 2016 #3 Only the hybrid drive and it will be used for casual gaming. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,751 22,089 184,590 Feb 15, 2016 Solution #4 Jeeperii : Only the hybrid drive and it will be used for casual gaming. Well...they're not terrible. I personally wouldn't, but you can if you want. Upvote 0 Downvote Solution
