Hi All,
I’ve been planning on building a new Micro atx pc for a while and with Ryzen looking promising I might finally do it. This is my current build:
Corsair 500R Case
Z77 Asrock Extreme 4 Motherboard
I5-3570K Processor OC to 4.4Ghz
Corsair h100i – Bit noisy and I’ve learnt alot since this my first build
Samsung 840 EVO 500gb SSD
2Tb 7200rpm HDD
Gigabtye HD 7950
Recently my GPU isn’t working and it’s either the motherboard or the gpu :/ (anyway it’s time for an upgrade).
Getting back to my question I’m wondering a couple of things if I should water cooling or Air cool and put the money into better hardware.?
I’ve done quite alot of research on water cooling and i’d either go with a EK pred with a water cooling block on the GPU say (£250 total). A full EK water cooling system costing say (£350). I could arctic cooler say iii- 140 (£100 and a cpu cooler).
Air Cooling I can get a decent Air cooler (maybe Be Quiet Dark Rock Pro 3 for £65) and i can leave my new Vega GPU with gigabyte or MSI air cooling solution. Therefore saving £200 ish. With this £200 more cash i could buy a much better gpu and cpu (currently thinking of spending gpu £350 and cpu £250 roughly) I can leave them not overclocked or even under volt and I would still get better performance.
Basically should I spend extra money on watercooling or Aircool and put the money into better hardware? Any of the components i’ve listed do you think there is a better replacement? I want the build to be silent and i don't really like the look of massive air coolers but maybe I can be convinced .
Corsair 500R Case
2Tb 7200rpm HDD
Gigabtye HD 7950
