Shuttle system SN41G2
Pokey302
11
Anyone here using that system? If so can u please post what drivers you are using for both nforce and the integrated videocard.
So far i have had nothing but trouble getting a combination to work. My best combination made the graphics hurt horribly but it did run. only bad scores on the benchmark and worse fps than my old pc.
My closest combination to be correct hangs at the WinXP screen for like 4 minuts before booting up. then it seems to run fine for a while ..then if i try to run a benchmark it will bluescreen on me.
im running the latest nforce stuff shuttle offered for this box. i tried the latest video drivers they recommend but thats where it keeps locking up during and after installing them(for about 4 minutes or so).
its a clean install of xp on a new hd. everything in my box is new. im just tryin to get it all setup.
Rehi Pokey,
Did you look at the BIOS upgrades?
<A HREF="http://www.shuttle.com/new/support/download/bios_rdm/readmefn41.htm
" target="_new">http://www.shuttle.com/new/support/download/bios_rdm/readmefn41.htm
</A>
Any of that apply to your system?
FN41S00X
Date code: 12/18/2002 Checksum: 2F00
Initial release.
FN41S00Y
Date code: 01/15/2003 Checksum: 3900
1. Fixed string error in VGA BIOS
2. Support Athlon XP 3000+
FN41S013
Date code: 03/13/2003 Checksum: 5B00
1. Fixed system unable to start when over 1.5GB memory modules are installed.
2. Fixed AGP TOP MEM program error when AGP card is installed.
3. Set CPU FSB default to 100MHz if AMD Duron CPU is installed.
4. Add Onboard VGA Subsystem ID.
5. Set DRAM to run 100MHz in fail-safe mode.
6. Added Warning Message in safe mode during POST screen.
7. Start system in safe mode after clear CMOS.
8. Sign on message change to "nVIDIA nFORCE 2 IGP + MCP-T".
9. Fixed error message in Devices Manager when only USB keyboard /mouse are installed under Windows 2000/XP.
FN41S015
Date code: 03/21/2003 Checksum: 5600
1. Added constant FAN speed control
2. Fixed Matrox Parheelia 4x AGP card can't display.
FN41S018
Date code: 05/02/2003 Checksum: 0E00
1. Fixed Athlon XP 2600+(Barton core) CPU show 1910MHz on POST.
2. Added Ultra-Low Fan speed Control.
Ultra-Low : 1700 PWM
Low : 2300 PWM
Mid : 2900 PWM
Full: 3500 PWM
FN41S019 Date code: 06/17/2003 Checksum: F500
1. Added DRAM Auto-Prehcarge function
There are two sets of drivers for XP
the VGA and the chipset drivers
<A HREF="http://www.shuttle.com/new/support/download/dwn2.asp?model=SN41G2
" target="_new">http://www.shuttle.com/new/support/download/dwn2.asp?model=SN41G2
</A>
Did you install both?
All three of these items seem relatively recent: 7/17/2003.
1) Bios
2) Win2K/XP VGA drivers
3) Chipset drivers
Seems to me that you really don't have a choice as to what to install. Install it all.
I also just noticed from your posts in the other section that you that you have an XP2600 but you didn't note if this was the Barton or ThoroughBred core and the bios update has something for the the 2600 Barton.
<b>
Hey people, I think Pokey needs some advice on how to cleanly install the VGA drivers under XP. Any advice for the man???
</b>
The loving are the daring!<P ID="edit"><FONT SIZE=-1><EM>Edited by Flinx on 07/23/03 11:11 AM.</EM></FONT></P>
ok...
i have updated the bios to the suggested one from shuttle (dating 7/17) sucessfully
i have used the nforce drivers suggested from shuttle (7/17) and updated sucessfully
when it comes to the video drivers, i tried the ones suggested on the site. it hangs during the install at a black for 3 minutes and it also hanges at the winXP screen during bootup for 3 minutes everytime i reboot after that.
i try different drivers for the video (from nvidia) and still same results
the ONLY way i can get it to run at an OK speed is by using the nforce and vid drivers that came with the cd.
sure dont sound normal to me. should i look into exchanging the shuttle for another one just like it?? or am i just thinking crazy
