Hi guys,
I'm happy to have solved my cooling issues that i had with a DeepCool Tesseract BF case by adding 2x BeQuiet! Silent Wings 3 120 mm high speed fans (1 intake in the front and 1 exhaust in the back) + replacing the I5 8500 stock cooler with a Dark Rock Pro 4.
My final question is - i would like to add a 140mm case fan on the side of the case - as the top side is now pretty much blocked by the massive cpu cooler.
I was thinking about the Be quiet! Silent wings 3 140 mm high speed as i am very satisfied with the other two fans that i have installed. My question is - should this 140 mm case fan on the side panel be mounted as intake or exhaust? I want this fan to cool the GPU, it's a Gigabyte Geforce 2070 Super GPU.
I'm having doubts if it's best to blow cool air (intake) on the GPU since it already has it's three fans which spread warm air away from it, would this not create a conflict with the airflow? Or does the side fan just blow cold air on the entire GPU if mounted as intake and thus reduce it's overall temperature better than exhausting that warm air through the side?
Thank you very much!
Kind regards and stay safe!
