Hi,
I have a Gigabyte 680GTX SO incoming, it has side fans so the exhausts heat towards the side panels. I've swaped the clear plastic side for a grill which does have fan mounting.
If I was to put fans on it should I exhaust heat - if bringing in air would I create negative airflow?
I will have another GTX680 running in SLI and an upgrade to a 1000w OCZ PSU so I think heat will be an issue - I'm pretty borderline with a 750w PSU and 2 x AMD 6970's.
Thanks
Thanks
