Hi! My PC consists off:
Asus P8B75-V
Core I5 3350p - cooler stock
16 GB DDR3 1600
Sapphire 7850 2GB
Corsair Rmx 650W
I have to buy 2 fans for the side panel of my CoolerMaster Storm Trooper, since my old ones have started to be very noisy. I also use all the stock fans that came with the case. I was thinking about these models:
1.Cougar Dual-X 120mm
2.Cougar Vortex 120mm
3.Noctua NF-P12-1300
A friend of mine also recommended an Arctic Cooling F12 model. I must say I will use them at full speed. (through molex).
Which one would you recommend, and is it really worth paying about twice as much for that Noctua version? Plus, are that Cougar fans reliable? Thank you very much.
Asus P8B75-V
16 GB DDR3 1600
Sapphire 7850 2GB
Corsair Rmx 650W
