Side panel for my Corsair 200r
AlexMk
4
Hello everyone,
I will be getting a Corsair 200r case for my new build, and i want to put a plexiglass on my side panel. Where could i find a clear (without mesh) side panel for it? Is there a spesifically designed one for the 200r, or can i find other ones that would fit on it?
Thank you.
other than that, you dont have much of an option then if you choose not to remove the side panel fan slots. case side panels arent very universal(in rare cases its possible, but most of the time no). the most you can do is look for an acrylic glass with precut dual 120mm fan slots, but that glass would probably cost as much as the case itself.
Yes i know, the problem is the Mesh for the fans it has on the side panel.
I would have to make the window way higher than i want to...
im not an expert of this but do i need to re-apply thermal paste on it or just rotate the cpu cooler 180 ?
Dude where did you get that from?
i live in Malaysia, i was building budget PC and choose the 200R as my casing and here i thought there is no side window for it just i like i saw at corsair's website. but when they finnish installed my budget pc i realise there's a side window and i was suprised myself
