I meant that the air got recirculated and reheated you moron, just like I SAID.
You've sprayed a ton of bull, but it doesn't add up.
I don't even know what you're talking about.
Admission of ignorance is the key to learning. There is hope for you yet.
Listen up: I'm not picking fights - I'm just correcting you because you don't understand simple airflow. You think you do and your bruised pride is blocking your capacity to listen and learn. You try to come off as some kind of cooling expert but all you do is spray a bunch of drivel. This round got started when you posted the following:
I'm a little ticked about a 25cm side panel fan that I bought for my Kandalf though, as it hasn't seemed to lower my temps on my CPU at all, and if anything they're higher with the fan panel. Air flow disruption. The big fan is circulating warm air inside of my case. Sure it's bringing in more fresh air, but by stirring it all up it's allowing it to stay in the case, where parts of the air get reheated. .
This, combined with everything you've said today just shows that you don't know what you're talking about. You're inventing flow scenarios that don't add up. I'll help you get back on track with a simple fact:
Air in = air out
This comes into play when you say the 25cm fan is bringing in more fresh air. Fresh air is cooler than the hot air inside the case, right? So the only way that you can hurt your heat flow when you add fresh air in is if that fresh air hogs the outflow. It's like I've said repeatedly, a large fraction of the 25cm fan air would have to be going right out the exhaust. If not, it would have to be displacing more hot air than when not using the 25. You're not blowing up a fricken balloon so you can crawl down off of your "circulating warm air inside of my case" soap box. Adding cool air in increases the potential cooling capacity
EXCEPT when it goes right to exhaust
WITHOUT circulating inside the case.
Fact #2: Typical ATX case air flow does not imitate laminar flow.
There are many angles, corners and obstructions. So, along with adequate front to back and/or bottom to top flow, some degree of circulation is a good thing. This has been demonstrated with IR photos and videos, smoke video, etc.
"Case in point" more fans are not always better. Without proper air FLOW, you're just blowing a lot of hot air.
If you're an expert on anything, it's blowing hot air. You get challenged about your ability to observe and reason and since you can't handle that, you decide to take cheap shots and call names. That's a sure sign of a dude that's lost an argument.
