News SiFive Tapes Out First 5nm TSMC RISC-V Chip With 7.2 Gbps HBM3
As long as we are still talking about one-bit-per-baud busses, the two are fundamentally interchangeable: each data pin of a 7.2GT/s bus is carrying 7.2Gbps.
While that may be true, shouldn't we try to use the correct unit to represent what's being transferred instead of the more common colloquialism?
This way, moving foreward, more people will start to understand the difference!
Using Gbps is pretty standard for chip manufacturers describing the bandwidth-per-pin/lane density of their interfaces.
GT/s will become awkward when more devices start using PAM4 and higher signaling like GDDR6X has. What is the GT/s rate of 19Gbps GDDR6X? Hint: the correct answer is not 19GT/s since GDDR6X uses PAM4 (2bits/baud) signaling.
