[SOLVED] Signal problem after RAM change
mihaisoroiu05
74
4
4,545
I just changed my RAM from 4GB to 16GB
The pc works fine but sometimes the monitor shows "no signal" then black screen and the monitor is fine again
After some time this happens again
Any ideas ?
Specs
CPU : R5 1600
GPU: RX 560 4gb
PSU: Zalman leii-700 (700W)
RAM: Corsair vengance lpx 16gb 2x8 2400mhz cl 16
Mobo: GA-B450M-S2H
sounds like one of your ram sticks is on the fritz, my advice would be, to take them out one by one and test them seperately, try and find which one causes you grief and have it replaced
