Hi,
I've got a P4 2.8 @ 3.15 with stock cooling and the noise is driving me crazy so I decided on buying the Arctic Cooling Super Silent 4 Ultra (I couldn't find the TC version where I live) and I've got some questions:
1. On they're site the note the the Intel stock cooling is better then the Super Silent (0.30°C/W against Intel's 0.28°C/W) what does it means for my pc (it peaks at about 65° C)
2.
Thanks for your help
Uri
By the way I know I should replace the P4 and I'm going to, but for now...
2.
Is this true should I be worried about my PWM temperature being 40°-50°C? (on Abit's uGuru its inside the normal scale) Should I get another case fan?Good system ventilation is crutial for the CPU cooling. The temperature in the area of the CPU cooler should never exceed 38°C. Therefore we recommend to use a temperature controlled Case fan.
Uri
