Hi all,
I've recently built a home theatre PC using the Gigabyte GA-8N-SLI Pro, however the system is too noisy using the stock CPU cooler. Now my problem is that with this mobo, is that I think the placement of the northbridge chipset retricts the size of the CPU cooler I can place on the mobo.
Also, do to the fact that mobo is in a HTPC box, I need to blow vertically upwards and I have about 10/11 cm in vertical height for fan/heatsink.
I've been searching for ages to a suitable quiet heatsink for this but I'm at wits end cause I don't want to take a risk and buy something that won't fit, so I'd really appreciate if somebody could help out. Any ideas what others have used with this board.
On a side note, what would you recommend for a quiet northbridge chipset fan. The stock one that came with the board is also a little noisy.
Cheers
Cheers
