Silicon Motion SM2258 Technical Preview With Micron 3D TLC NAND
  • Thread starter Thread starter Guest
  • Start date Start date
tlc have 3-bit cells. there are 8 levels of states (not sure if these are volts or amps), each level give a binary number between 000 and 111, so can represent 3 independent bits. To have 2 independent bits, you only need to reliably distinguish 4 states, which is obviously easier, but the 66% less memory per density.
