In addition to the above it would help if you would tell us precisely what device the android is running on. Certain cell phones require use of a specific format on external drives and usb devices. This may trigger your "need to format" message and you may have to allow the phone to format it according to the phone's requirements. You may not have a choice of format.What app will detect this hd. And how do I fix the error of having to format?
Thread starter | Similar threads | Forum | Replies | Date |
[SOLVED] A good software for checking GPU/CPU performance and power consumption ? | Apps and Software | 5 | |
R | [SOLVED] MSI Afterburner doesn't show CPU power on 13th gen | Apps and Software | 2 |
