I used Tomshardware's SSD reviews to arrive at the decision to buy a 1TB Phison E12 equipped SSD. Then it came down to which brand/model and the Silicon Power P34A80 was the least expensive and through reviews, deemed to be comparable to Phison's own reference design, and that of other E12-based cards.
Imagine my surprise when I receive the 1TB model and it has completely different components than the one pictured on Tomshardware review. https://www.tomshardware.com/reviews/silicon-power-p34a80-pcie-gen3x4-m-2-nvme-ssd,6180.html
The model number is the same, however the one I received is using flash from a Chinese company "UNIC" and instead of Hynix DDR4 DRAM, the card I received is using Nanya DDR3 modules.
At first glance this seems like the classic bait and switch-- Silicon Power changing components to ones they can source much cheaper, and leaving the model number the same so as to swindle buyers... But then I question whether I'm being too pessimistic? Surely reverting to DDR3 for the buffer would have a performance penalty.
What do you folks make of this? I'm not going to be the guinea pig for performance testing; I'm sending the card back and getting a brand with known Toshiba flash. I think a component change of this magnitude warrants a new model number or revision suffix at the very least.
