Hey, I'm lookin to upgrade a PIII system to a new P4 everything. I know I need a new power supply for the P4 mobo extra connections (as well as likely needed more wattage anyway). Is there any reason I can't use my very roomy mid tower ATX case? I can't think of anything that has changed that would make the case unusable, but I'd rather be aware of any silliness before I order all the parts.
Secondly, what size power supply is the norm these days? I'll be running a new mobo and Intel chip in the 2-3 GHz range and (hopefully) a new mid-high-end video card.
While I'm askin questions, I suppose I should ask about cooling as well. I currently have a front and rear fan pulling air from the front to the back with a fan duct pulling air off the CPU and out the back. Will I need more active cooling with this kind of setup? If so, would a drive bay or PCI fan do the trick as I'd rather not drill holes in my case.
Thanks for any help you can provide.
Leebier
Leebier
