• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Silverstone fan hub?
zionxninjafrost
8
Bought this fan hub and at first it ran all my fans at full blast. So i read some forums and they said to connect it to the cpu fan, and i did. It stopped the full blast but now i cant control my fans but only my rad fan.
Sedivy
Estimable
Dec 17, 2016
2,324
497
Normally your case fans are regular dc fans. This fan hub is pwm. If you plug a dc fan into pwm, it'll likely run full blast as you can't control its speed. It says as much in the specifications here: http://www.silverstonetek.com/product.php?pid=526&area=en
* Speed control function is unavailable for 3 pin fans.
But it's no loss because you couldn't control them before either. They just ran full blast. They should still just run full blast.
What's a rad fan? Radiator fan? Do you have an aio with its own set of fans? Cause those shouldn't be plugged into that fan hub.
zionxninjafrost
8
I have hd120's=4 pin and my "rad fan" is my hd120's that I have setup as pull behind my rad. I have the fan thats behind my rad plugged into the hub along with 2 more fans. but my pump is connected to my mobo
zionxninjafrost
8
MSI Z97 gaming 3, Corsair h series h70
Sedivy
Estimable
Dec 17, 2016
2,324
497
Ok from your mobo manual you have 2 cpu 4 pin connectors and 3 4pin system connectors. https://us.msi.com/Motherboard/support/Z97-GAMING-3#down-manual
So, I would plug your aio fans individually into the 2 cpu 4 pin connectors, on the page 1-7 of your manual marked CPUFAN1 and CPUFAN2. Then go into bios and adjust temp/rpm curves of these two fans to respond to cpu temperatures as you wish. To control them from within windows, get command center utility: https://us.msi.com/Motherboard/support/Z97-GAMING-3#down-driver&Win10%2064
I would then plug the rest of your 4 pin fans (if more then 3 otherwise you don't need a hub) into the hub, and the hub sensor connector into one of the remaining 4pin system connectors on the mobo (marked SYSFAN1-3 on page 1-7). Adjust their speeds by again in bios adjusting the temp/rpm curve for that header, and then in command center if you want to further tweak it later.
I'm going to change some of the recommendations above based on what you tell us of your hardware.
First, the mobo has two 4-pin headers for CPU cooling - CPU_FAN1 and 2 - that really do use the PWM Mode to control their fans, so those can ONLY be used with 4-pin fans. Then it has three SYS_FAN 4-pin headers, BUT they only use Voltage Control Mode (aka DC Mode). Such a header CAN control the speed of either 3-pin or 4-pin fans. HOWEVER it can NOT be use to connect a 4-pin fan HUB, because that header type does not provide the PWM signal the Hub needs.
Second, the Silverstone Hub is a true 4-pin fan Hub. It can ONLY work when connected to a mobo header that uses PWM Mode, and can control ONLY 4-pin fans. Now, you speak of having "HD 120's" that are 4-pin. The only HD 120 fans I found on the Corsair website are LED units, so maybe that's what you have. But it does not matter if ALL your case fans are 4-pin. You also say that, although the Corsair H70 unit came with a pair of 3-pin fans, you are using a pair of those same 4-pin HD120 models on the H70 radiator.
Under ideal circumstances you would have your CPU cooling system connected to the CPU_FAN header so its automatic cooling controls are based on the temperature sensor inside the CPU chip. Separately, you would have all your case vent fans plugged into mobo SYS_FAN headers and ensure that they are using the motherboard's temperature sensor to guide them. What I will recommend is that you do just that. Even though the three SYS_FAN headers on your mobo use Voltage Control Mode, that method CAN control the speed of 4-pin fans, too. It is not completely ideal, but it works well. The only consideration there, then, is that you have only three such SYS_FAN headers to use. IF you have more than three case vent fans to connect, you might need a SPLITTER (not a Hub) to help out with those.
So, first the CPU cooling system. The H70 system is designed to power and control the CPU pump unit and the two radiator fans separately. For this purpose you can use the Silverstone Hub to advantage. It has two cables that plug in. One ends in a 4-pin female fan connector and MUST plug into a mobo CPU_FAN1 header. (CPU_FAN2 would be just as good for this case.) The other cable must plug into a SATA power output connector directly from the PSU to provide power to the Hub. The 3-pin fan connector on wires coming from the Corsair H70 Unit's PUMP should go to the specially-marked Port #1 of the Hub. This is the only Hub port that can send back to the CPU_FAN header the speed of the device (in this case, the fan) plugged in there. That is important because the CPU_FAN header does extra monitoring of that speed to ensure that it IS working and there is no danger of CPU overheating from poor cooling. Then the two radiator fans can plug into other ports of the Hub. In this configuration, the PUMP will run at full speed all the time because it is a 3-pin device plugged into a 4-pin header using PWM control., and the pump's speed will be reported to the mobo header and closely monitored. Be aware that the BIOS fan control screens may call this speed the "CPU Fan", even though it is really the pump. Then the actual fans on the radiator WILL be speed-controlled by the signals from the mobo header relayed to them via the Hub, based on the temperature actually measured inside the CPU chip, which is ideal. However, there will be NO way for you to "see" the speeds of those two fans - there is no place to send their speed signals for monitoring.
For the case ventilation fans, plug each of them into its own SYS_FAN header. They WILL be speed-controlled automatically by the mobo guided by the mobo temperature sensor, and you will be able to "see" their speeds in BIOS. IF you have more than 3 case vent fans, post back here with a count and we can advise on using splitters if necessary.
See your manual on p.3-30 to configure the fan headers. For the CPU_FAN, ensure that it is set to use the "Smart Fan Mode" for automatic control. For the SYS_FAN headers, ensure that EACH of them is also set this way. But in addition for these three headers, look for an option to specify what temperature sensor is used. If possible, ensure it is the motherboard sensor, not the internal CPU chip sensor, used for these SYS_FAN headers. Remember, when you make any changes to settings in BIOS Setup, you must SAVE and EXIT to save them and reboot.
Sedivy
Estimable
Dec 17, 2016
2,324
497
Yeah paperdoc is right. I did not read the manual closely enough. They're not true 4 pin headers for sys fans. Just follow his instructions, it's a much more appropriate setup.
Similar threads
