Silverstone PSU Fan Not Running
lucamakar21
25
Hey guys, my psu fan does not spin but my computer boots up and works perfectly fine. Should I be worried about the fan?
You'll have to open the case and look at the PSU label to get the model# to know for sure. Pretty much all PSU other than bargin basement ones these days have silent running as a feature.
You can try testing it by putting a load on the system. Usually playing a game that cranks the CPU&GPU up will do the trick.
Honestly I am not sure, it is a 1200W so I am assuming pretty high end. I would have to remove the power supply to see the exact model as I was given this power supply. Should I just run some games and see if the fans turn on?
