SilverStone's Raven RVZ01 Mini-ITX Case Finally Hits Shelves
U.S. pricing is $85http://www.amazon.com/Silverstone-Tek-Mini-ITX-Computer-RVZ01B/dp/B00I3EKXDE/ref=sr_1_1?ie=UTF8&qid=1392376722&sr=8-1&keywords=RVZ01
Really would like to build a system with this. But only can put it horizontal. Fear that cooling is not so good then. Will wait for reviews!
This is probably the best mini itx case you can get. There haven't been many really small, console sized ones yet and this is it. It will be the DIY steam box and it is very similar to the Alienware X51 in the design and the pcie riser card is awesome.
Awesome! Are the 600w sfx power supplies out yet?
Not yet through Silverstone. I haven't considered other companies since the only other ones that make SFX are either 300 watt or less or by unproven companies.BTW, for anyone who wants to order one of these cases, I'd suggest going through NewEgg instead of Amazon. NewEgg claims they're in stock where with Amazon I won't get the case until the middle of March.....
supports slightly longer cards? if by that, you mean 13.5 inch cards, which is linger than the 690 or the 7990, then yeah, thats a little longer than a short dual slot card. and they dont need to be water cooled, a full dual slot air colled card will fit in this thing.
