Question Simple CPU question.
Bazzlebrush88
82
6
4,535
If a CPU is not in the socket if you pushed the power on switch, should nothing at all happen.
I know nothing would work without a CPU, but before getting the cpu I wanted to somehow test the motherboard to at least see if that was working before installing CPU.
So like a full on noob commander I pushed the power switch on, the power switch lit up and then went off. Nothing happened inside the case. Is this normal until it has a CPU in?
Thanks in advance, Craig
