this might be a useful update for people experiencing crashes on the HD4850.
i am running the following:
ASUS M4A78 Pro motherboard
AMD Phenom II x4 920 processor
4gb Corsair RAM
Windows XP SP3
Dual Viewsonic 17" wide displays
Acbel 450w PSU unit
i was experiencing crashes with Assassin's Creed, but put it down to buggy software (after reading some forums on the game).
after installing Terminator Salvation and still getting crashes (sometimes BSOD, sometimes no signal, sometimes vertical banding),
i finally decided to do something about it.
i spent some time reading game and hardware forums and decided that there were several issues that could be causing the crashes:
- driver issues
- temperature issues
- PSU issues
temperature wasn't a problem for me (idling at 55degrees, running COD4 and 5 pushed it up to 70degrees max). since i couldn't get
better cooling, i took of the side of my casing and directed a fan at the insides as a short term fix.
i spent the past 3 days taking care of the driver issues, uninstalling, cleaning, reinstalling ad infinitum, like a good boy, i had
installed all the drivers and mobo-related utilities on the installation CDs (SmartDoctor, EPU, Cool n Quiet, GamerOSD, AMD
OverDrive etc), but still nothing. i also downloaded and updated all my drivers, cleaning the old ones out first with Driver
Cleaner Pro. i also tried endless combinations of old (stable?) drivers with newer updates. NOTHING WORKED.
FINALLY, an hour ago, something worked!
- i used CCleaner to remove ASUS GamerOSD, AI Suite, SmartDoctor and EPU from starting up (catalyst 9.9 starts up as usual), just
in case i would need them later.
- next, reboot and went into bios and changed the AI Tweaker > AI Overclocking setting to MANUAL and left the default values as is.
- went into my OS and booted up Assassin's Creed and actually played it without crashing for an hour!
my next step would be to reinstall Terminator Salvation and try it out. IF it works, i will reinstall all the ASUS software overclocking crap. if anyone else has issues with your HD4850 crashing, please try this out.
