Hello JimF_32
i had checked and changed my PSU,RAM,processor,POWER WIRE,INTERNAL WIRES everything's but its not powering on. but when i opened pc case and putted out motherboard and i checked it properly but i didnt get any black parts at all.when i connect psu with my board and pressed power button again its not powering on but one thing i had noted that when i am switching on power button a indicator is blinking between back USB port and LAN port.>>>>>USB PORT"
blinking
"LAN PORT<<<<<its only happened when i am pressing power button.
Sir its my final report with every details.please give me a working solution for my pc.its about a week going on and all my work is still pending.its my humble request to you please solve this problem as soon as possible...
Model No...............SIMM-INT G-41D3 (V1)
CPU......................Intel Core2 Extreme/Core2 Quad/Core2 Duo/Pentium
Dual-Core/Celeron Dual-Core/Celeron Processors with
LGA775 CPU Processor Series
FSB.....................FSB 800/1066/1333 MHz
Chipset.................Intel G41 + ICH7
Graphics Interface..GMA 4500
Memory................Support DDR3 x 2 1066/800, Max Capacity 8GB
DDR3 DIMM Sockets(QTY)....2
Integrated LAN......RTL8105E 10/100Mbps (RTL8111E 1000Mbps Optional)
HD Audio.............Codec ALC 661 (6 Channel)
Support I/O..........NCT5577D
Support.............1xPCI Slots, 1x PCIE x 16 Slots, 1x PCIE x 1 Slots
Back Penel...........4x USB Port (Qty) , PS/2 Keyboard, PS/2 Mouse, VGA Connector, Analog Audio Ports 1 x 3 Phone Jack, 1x RJ45 LAN Connector
Internal Headers......4x SATA Connectors , 1x IDE Connectors , 1x USB Header (2x5 Pin 9 Keyed), Seriel Port Header, Chassis Main Panel Header (2x5), Audio Header(2x5) , S/PDIF Out Audio Header (1x2) , Internal Speaker Header (1x4)
Power Headers..........Universal Power Connector 2x12 + 2x2
Thermal Headers........CPU Fan, Form Factor Micro ATX (235mm x 170mm)
Ram..............Samsung 2GB 2RX8 PC3-8500U-07-10-B0
Motherboard........Simmtronics G41D3V1R1 dual channel ddr3
Processor........intel i86 E5300 PANTIUM DUAL CORE 2.6GHZ/2M/800/06
Processor fan....Intel DTC-AAT06 12VDC 0.60A DELTA
Power supply......Zebronics (ZEB-450WDSATA)
Harddisk.......1.0TB SATA/64MB cache
