Simultaneous Streaming and Recording w/ Quick Sync and Shadowplay
RamboUnchained
86
I'd like to know if this is possible. If so, it's going to save my friend about $100 on his next build :bounce:
If it's possible, he can just get a non-k 4670 and a 212 Evo instead of a 4670k and a H100i.
Not really answering the question here, but you should convince him with the price
Comparing this
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($159.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($119.99 @ NCIX US)
Total: $244.98
(Generated by PCPartPicker 2014-03-16 02:58 EDT-0400)
vs
CPU: Intel...
shadowplay is supposed to work like fraps without a performance hit. quick sync is also supposed to perform well without as much performance hit. i would go with shadow play though
and if he doesnt want to overclock he should go with the non k designator processor(or whichevers cheaper) and he can run with a stock cooler
the evo will get him cooler temps but nothing should be high as it is not going to be over clocked. the only difference between the 2 is the k can overclock the non k cant
If they cant be used simultaneously, he's just gonna OC his 4670k so he doesnt take much of a performance hit. He's only getting a 750ti for his build. He wants to be able to record while he streams using only shadow play and quick sync.
He wants to be able to record with shadow play while he streams using quick sync if possible.
If I understand correctly, using shadowplay takes load off of the GPU and quick sync drops CPU usage like crazy during streams. I've seen reports of shadowplay only dropping FPS by 5-10, and quick sync uses the integrated graphics for all of the encoding. The only CPU usage he'd have would be split between xsplit, the game itself, iTunes, and the twitch dashboard. I think he uses Firefox.
Ah I didnt know that.
Comparing this
Total: $244.98
vs
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($209.99 @ Amazon)
Motherboard: Asus Z87-A ATX LGA1150 Motherboard ($129.99 @ NCIX US)
Total: $369.97
(Generated by PCPartPicker 2014-03-16 02:59 EDT-0400)
Now I'm not saying AMD is the best in performance, but it is in his situation, most likely.
yea if he only has the budget for a i5 then he should go for the 8320 and overclock it. if he wants to shell out the money for the i7 he would get better performance but its a pretty big price jump if he is on a budget and i wouldnt reccomend the i5 for this particular situation you def need a cpu that can handle a lot of threads
THAT'S what I'm trying to get him to understand. He already has a Builder Series 430. I told him that since he's getting the 750ti, he'd still have plenty of overhead for an AMD OC that will give him similar performance to the Intel. It's like preaching to the choir when you're trying to talk to someone that's used Intel-based PCs and laptops for the past 10yrs.
He's a strong believer in "you get what you pay for." His house wreaks of overkill appliances for what they're used for lol.
This is his first custom build and he has me doing all of the work for him. Go figure.
He "can" spend the money, but he doesnt want to put a lot into the system right off the bat. Which is understandable.
