Hello ... i don´t know if it´s really like the title says or not but...i think i am noting the things are like slower than before 4 or 5 days...
Can it be the current temperature of my place?
Note we are in summer but i am using the computer middle of the day only when its hot (from 7:00 or 7:30 am to middle of the day) and at afternoons if i have split air conditioned turned on only.
Yesterday i did 2 screenshots:
1)
with Aida
2)
In the 2nd screenshot it says the gpu core temp is 40 while the max is 40,5.
This can be the problem?
In the case it is not the problem, what other things should I check?
Note i dont have antispyware software in the computer. What one do you reccomend (free if its possible) to check and clean?
And what another infos do you need?
Thank you in advance!
1)
2)
