I recently built a new computer and I noticed that when running a single stick of ddr4-3000 corsair ram my bios showed a speed of 2133mhz and the respective amount in CPU-Z. However, when I installed the other stick of Ram from the package the speed dropped to 800mhz in bios and 400 in CPU-Z. Not sure what could cause this problem or how to fix it please help.
Motherboard: MSI Z390-A Pro
Ram: DDR4-3000 Corsair Vengeance LPX 2x8gbs
GPU: GTX 1660ti
CPU: i5-9600k
I tested the a set of 2x8gbs of the ddr4-2400 memory that I have in the computer I built a couple years ago and the same thing happened.
I also tried to manually set the ram speeds and turning on xmp but that led to the computer not being able to boot properly.
Both sticks of Ram work individually and are able to run at 2133mhz on their own and boot the computer.
GPU: GTX 1660ti
CPU: i5-9600k
