Single DIMM DDR3 has lower(better) tRFC than dual kit?
sportsonpraks
Commendable
Feb 23, 2016
Ok, here is the situation:
I originally had two single DDR3 G-Skill sticks F3-12800CL9S-4GBXL (note the 'S'). Total 8GB in dual-channel running in slots 1 and 3.
The two sticks were running XMP at 1600 MHz with the rated 9-9-9-24 timings.
tRFC was at 128 (confirmed in CPU-Z and BIOS).
Motherboards (Biostar Hi-Fi Z87X 3D) 'Memory Insight' also showed tRFC for the sticks to be 128 as well.
Now the problem:
I recently purchased the dual stick kit of the same model F3-12800CL9D-8GBXL (note the 'D') to upgrade my memory to 16 GB total. This is a 2X4GB kit.
I inserted the two sticks in slots 2 and 4 only to find that the system does not post. So after several failed POST attempts the BIOS got reset to its default settings and the POST was successful. Went into BIOS and found that the new sticks had tRFC rated at 208 compared to 128 of the original single sticks.
After enabling the XMP the system booted fine. The speed was 1600 in dual channel with 9-9-9-24 timings. However, with four sticks in place the tRFC was at 208 (as reported in CPU-Z and BIOS)
Motherboards memory insight showed tRFC for the new sticks to be 208 (slots 2 and 4).
Questions:
- Why do the single sticks have better rated tRFC of 128 while the dual stick kit has 208?
- tRFC being secondary timing is not found in the specifications at the products site and the package. How would a customer come to know about it before purchasing?
- The general understanding is that the dual kits and quad kits tend to be expensive since they have been tested to work well together. However, the single sticks have better timings and had no issue running XMP in dual channel. Then why are the dual kits more expensive?
I understand that two different makes of same model can have different secondary timings but this information should be available to the purchaser before hand so that he is able to make an informed decision.
Now, I tend to believe that I would have been better off with purchasing two single kits itself that would have yielded better tRFC and would have been less expensive as well (not by a great margin though)
Other Information:
CPU: i5 4670K
Motherboard: Biostar Hi-Fi Z87X 3D
Hi,
tRFC is the Row Refresh Cycle Time.
All DDR3 DRAM chips must refresh each row on each bank no less than once every 64 milliseconds in order to maintain data integrity. As a matter of practice and design, the memory controller will issue an auto-refresh command on average once every 7.8 microseconds (or once every 3.9 microseconds at temperatures above 85 degrees centigrade).
Since the number of refreshes per unit time remains constant, it follows that DRAM chips that have more rows must refresh a greater number of rows per refresh cycle. This requires the DRAM chip to draw more current; in order to prevent localized overheating, the current draw of the chip is limited. Thus, higher density chips take a longer period of time to refresh.
A 208 cycle tRFC is the standard cycle time for a 4 gigabit DDR3 DRAM chip running at DDR3-1600 data rates (800Mhz clock). If you take a look at the two new DIMMs that you purchased, you may notice that they have chips on only one side.
Thanks for the reply.
tRFC being a rating of the stick, who dictates what value is to be used? The original sticks had 128 and were working on that rating in XMP. Are you saying if I had bought two new sticks with 128 tRFC the combination of all four would still run at 208? Even though each has been rated at 128?
What concerns me is the lack of availability of this information on product's catalog.
Thank you for that great insight.
If 208 is a standard for 4 GB DDR3, that means the original DIMMs had a better rating of this timing. I just need a way to know before purchase what it is for a particular model & part number.
