[SOLVED] Single fan and Double fan GPU is it any difference in performance ?
Aug 30, 2020
5
Hi all...
I am wondering is there any difference between single fan GPU and double fan GPU except on the form factor? i mean is it effecting their performance as well?
ie : gtx 1650 Super mini single fan vs gtx 1650 super regular form factor.
Dual fan would help in dissipating heat from the card faster and ofc, if you look under the fans, you'll see that the heatsink often times is a beefy version when compared to a single fan version GPU(within the same series). Apart from cooler temps, if you try your hand at overclocking(mildly) you should see better temps on the GPU as opposed to a single fan design card.
Reactions: Merlin14
