Single GPU Running hot.
robosodope
45
I have an SLI set up which I have overclocked. When I play a game like Dishonoured 2 one of the GPUs gets to about 75-80c and the other one around 55-65. I don't know if the difference in heat is bad or alarming.
80 sounds a bit hot but not much, is the first gpu, the one on the top near the cpu?
how much space is between that one and the second gpu on the sli?
at least one slot or are both together?
the cards will work well on those temperatures, if they go over 9'° they will throtle to keep temperatures low
