I recently decided to consolidate my more everyday hardware into an HTPC / NAS to achieve peak performance from my gaming rig, but have been fighting with a ridiculous problem for the past two weeks.
The 2U case I used can horizontally mount the GPU and capture card I have. The problem is that this will not clear with either USB 2.0 header connected. The capture card is literally resting on the PCIe slot adjacent the header, and the RGB I plan to use for temp monitoring needs a USB 2.0 header.
Several 90-degree adapters and cables failed to solve this problem. A PCIe card is not an option as riser cables are in the way.
I considered an M.2 to USB header adapter, but can't seem to find one that doesn't require an existing USB header. However, I've discovered that the listing for the case states the front USB 3.0 ports ARE 2.0 compatible.
Pinout diagrams suggest that two 4-pins could be plugged into a 9-pin. So is it possible to adapt the 20-pin 3.0 header (which will clear) to dual 4-pin or 9-pin 2.0 headers so that the front USB ports can be retained?
It's not a 100% deal-breaker if I can't, but I'd rather not as I'm using a wireless USB keyboard / mouse, and would rather not use an extension cable from a rear port. A workable pass-through solution is fine too, as long as it will fit. This case is challenging and does not allow much space for cable management.
