Question Size (24" most probably) vs. Resolution recommendation for general purpose monitor
bat0nas
21
Hi,
As this monitor will be mainly for browsing, document editing, homework,, photos and just light gaming - image quality is a priority. So I should go with IPS then.
But what are resolution recommendations for 24" monitor?
Do I understand correctly that at 24" full hd is more than enough? At what size higher resolutions are needed?
I see almost none 24" IPS panels with FreeSync. A bit more with TN but not many as well. So if I go for a 24" I'm basically stuck with a very basic 60Hz monitor. Right?
Those recommendations kinda depend on your vision. With age - vision gets worse.
If you're in your 20-ties, with perfect vision, then even 1080p 22" would be fine.
If you're in your 40-ties, probably using glasses, then
skip 24" altogether,​
1080p - 27",​
1440p - 32".​
Latest posts
