Question Size help
Aug 10, 2022
Please redirect me if this is the wrong thread, but: I'm planning to build a PC. I just noticed that my GPU (Asrock Radeon RC 6700 XT 12GB GDDR6 Challenger D) is 324mm, and my case (Cougar MX410 Mesh-G RGB Gaming Midi Tower) can fit a GPU up to 300mm. Is there any way to make it fit, or should I choose a new one? (I'm going to give my complete build in case it helps)
CPU: Intel Core i5-12400F
GPU: Asrock Radeon RX 6700 XT 12GB Challenger D
STORAGE: TeamGroup MP33 SSD 1TB M.2 NVMe PCI Express 3.0 ×2
MOTHERBOARD: MSI PRO Z690-A WiFi DDR4 ATX LGA1700 Motherboard
POWER: Corsair RMx (2021) 850W 80+ Gold Full Modular
CASE: Cougar MX410 Mesh-G RGB Gaming Midi Tower
RAM: TeamGroup T-Force Vulcan Z 32GB DDR4 RAM 2 Modules (2×16GB) 3200MHz
COOLER: Arctic Freezer 34 eSports Duo Cooler
CASE COOLER: ARCTIC P12 56.3 CFM 120 mm Fan
CAMERA: Creative Live! Cam Sync 1080p Web Camera Full HD
OPTICAL DRIVE: Asus DRW-24D5MT DVD/CD Writer
MONITOR: Asus TUF Gaming VG27AQ 27.0" 2560×1440 165Hz Monitor
KEYBOARD: MSI Vigor GK20 Gaming RGB Wired Keyboard
MOUSE: MSI CLUTCH GM30 RGB
SPEAKERS: Logitech Z150
OPERATING SYSTEM: Microsoft Windows 11 Pro 64-Bit
Phaaze88
Ambassador
Max gpu length:
300 (mm) / 11.8 (in) (Only fans at the front panel)
270 (mm) / 10.6 (in) (Radiator with fans at the front panel)
You'd have to give up a front fan or 2, but it would fit with 1mm to spare.
Aug 10, 2022
Max gpu length:
Thank you!
Aug 10, 2022
Do you mean chose a new gpu or a new case?
I think you should change one or the other if you have not bought them.
Many cases work and many graphics cards will perform similarly.
I mean, is there a way to fit the GPU or should I choose a new case? I will search for a new case though, also no I haven't bought them.
