SK43G mobo battery problem
user
Splendid
Dec 26, 2003
3,943
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
My recentley purchased SK43G keep dis-charging the onboard battery -
it will last for about a month before becoming too flat to maintain
the bios settings.
Is this a common problem ?
>the bios settings.
No, I don't beive so, and it shoul not be like that, so you should get
it fixed/replaced.
Clas Mehus
Dataguiden : http://www.pcworld.no/dataguiden/
"Den som har flest prylar när han dör vinner..."
I purchased it mail order and have since found out that the company
has not got good reputation for refunding or replacement parts.
I was hoping somebody may know if the fault is fixable - DIY style !?
On Sat, 21 Aug 2004 12:56:24 +0200, Clas Mehus <clas.mehus@idg.no>
>>the bios settings.
>it fixed/replaced.
Maybe Shuttle can provide som direct RMA. Very hard to tell what this
type of problem will be.
Clas Mehus
{+}{+} <me@home.com> wrote in message news:<rojci0df0mu6n669467mtfhmg7dfigluto@4ax.com>...
> the bios settings.
I purchase the same in January and the battery died about a month ago.
I was away for about two months, so the sk43g was not on for that
period. I contacted the tech service and they offerred to replace the
mb, within a week. But, I declined and replaced cmos battery instead.
If it (the battery) died again, a replacement probably is the only
solution.
I also replaced my battery , but it only lasted for about 6 weeks
before it needed changing again.
>> the bios settings.
>solution.
