Skylake Build for 3D Rendering, Programming, and Gaming
brainstormplatform
Commendable
Jun 24, 2016
4
Hey guys! So for the past few years, I have been using a Thinkpad for the activities mentioned in the title. I work with Java and some C++, lots of Autodesk applications, and some light gaming. Lately, the laptop has started to die on me and I would like to build a desktop as I have a few more years till going on to college.
I want to keep my budget as close to $800 as possible and I already have peripherals such as a keyboard, mouse, monitor, etc... Also, I have already purchased Windows 10 as well as other nontransferable software.
For many of the components, I was torn between i5 or i7, Asus or Gigabyte mobos, but in the end, I went with a Gigabyte micro ATX so I could fit two monitors on my desk (one for command prompt, the other notepad or whatever I use).
There is no video card selected because I am waiting for the release of the RX 480; obviously, I could've just gone with a GTX 750 Ti and be done with this all, but the price to performance of AMD's Polaris series is too (compelling?) Just to be clear, I do intend to overclock- hence the K series chip
Leave your comments, what I should add / remove / or change altogether. Thanks!
Here is my part list:
http://pcpartpicker.com/user/brainstormplatform/saved/kCTdnQ
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($239.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($77.88 @ OutletPC)
Memory: Team Dark 16GB (2 x 8GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive ($35.99 @ NCIX US)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($69.00 @ B&H)
Case: Thermaltake Core V21 MicroATX Mini Tower Case ($58.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($64.99 @ Amazon)
Other: RX 480 ($200.00)
Total: $796.83
Generated by PCPartPicker 2016-06-24 21:29 EDT-0400
A Xeon is your best bet. 8 threads for i5 proce. Though its haswell, it doesn't affect much. Also I mean you get a single good hard drive for fast storage and a good SSD for boot. Also the RX 480 is a great option.
Asrock make great mobos, only some have minor issues. That board seems good. Also I mean the PSU is good. Tier 2. So I mean with these changes you are for the better. RX 480 4GB is 200$ good enoguh and will greatly outperform the 750ti. It's a 970 vs a 750ti basically.
Overclocking the 6600k won't even match close to rendering performance of the Xeon.
Also if you use cuda acceleration over OpenGL, NVidia is your best bet. 1060
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($219.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.99 @ Amazon)
Motherboard: Gigabyte GA-Z170M-D3H Micro ATX LGA1151 Motherboard ($104.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($52.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($154.85 @ Amazon)
Case: Thermaltake Core V21 MicroATX Mini Tower Case ($49.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($48.99 @ NCIX US)
Other: AMD RX 480 4gb ($205.00)
Total: $871.79
Generated by PCPartPicker 2016-06-24 21:37 EDT-0400
A slightly cheaper mobo and a better cpu cooler.
SSD makes a HUGE difference for programming and general usage and boot times. If you need more storage, you could get a 1tb HDD later on.
I put the rx 480 in there with a speculative price.
Your other parts were good.
