Skylake MSI Help
societyx
33
So I'm doing a Skylake build here and I'm having some problems. I think it may be a faulty mobo but I figured I'd post it up here anyway. I did the Step by Step linked by others on here already to check everything. Here's a brief list of what I've done..
> Unplugged, replugged in all the relevant PSU connections.
> Checked all the mounts and also unscrewed entire mobo, reseated, rescrewed it entirely to confirm it was properly mounted.
> Swapped RAM sticks around, tried one, etc.. the usual..
> Pulled and reseated the CPU
> Tried with, and without, a GPU of any kind installed in PCI-E, also tried different ones.
> Unplugged all HDDS and Opticals.
> Basically removed all connectors cept the most basic PSU ones. Also went back and checked Jumpers such as some said confirm LN2 mode isn't on.
None of this has so far yielded any more result than I started with. I boot up the system and it simply sits there. No picture comes up on Monitors, no BEEPs, and the onboard Diagnostic Codes simply display "0 0". Specs are as follows..
Mobo: MSI Gaming M7
i7 6700k Intel CPU
H105 Corsair AIO
Geforce 760 GPU
16 GB GSKILL RIPJAWS DDR4
EVGA 850 GA PSU
I did not, I am not familiar with paperclipping. Though I think this one came with a 'tester' that I think I read makes it unnecessary to do this.. might need to reread this.
