Specko1903 :
So when someone calls me/I call someone on Skype i can hear the calling sound but when we join the call the audio doesnt exist anymore (but the person can hear me speaking). Also when i try to switch the audio devices it works, but my headphones should work too since i use them every day on discord, i tried reinstalling skype, heaphone drivers and replugging heaphones to different usb ports but nothing seems to work
Heaphones- Razer Kraken USB
Os- Windows 8.1
Desktop skype for Windows 8.1
First, make sure you and the person you're calling install the latest version of Skype, check that you have a good connection, and close any applications that might be interfering with your call - then follow these steps:
Make sure your microphone and speakers aren't blocked or muted, and are plugged in if you're using a computer.
Try moving closer to the microphone, reducing background noise, or cupping your hand in front of the loudspeaker if you're on a mobile device. If you're using a headset, try using a different cable or plugging it into a different port.
If you're using the integrated microphone and loudspeaker of a PC, laptop, or tablet, try using a USB headsets and webcams to use with Skype.
Make a test call.
Skype's free test call is the easiest way to test your sound - it prompts you to record a message, and then plays it back for you to hear.
How to make a test call. If you can't hear the voice on the test call, continue to the next step.
Check your audio.
Try playing a song or using another application with sound. If you can hear it, the problem may be with the other person on the call - ask them to follow these steps too.
on
Windows desktop: Select
Tools >
Options >
Audio settings, then in the Speakers drop-down choose the playback device you want to use. If you're still having problems, Microsoft has a tool to
automatically diagnose and fix audio problems.
Hope it Helps
![Bounce :bounce: :bounce:](/data/assets/smilies/bounce.gif)
