JETSTAIN777 :
VincentP :
If your minimum frame rate is over 30 fps, the graphics should be smooth.
Skyrim isn't a twitch FPS game where you ultra low response times.
It doesn't really sound like you have an issue.
Skyrim is often described as CPU intensive, but that isn't to say it cannot be graphically intensive too.
It has always been possible to add mods that improve graphics and can bring many high end graphics cards to a crawl.
Now there is an official graphics refresh version as well.
If you want better frame rates or improved graphics, you need a better graphics card.
The GT 740 has a passmark score of 1579, although I suspect this includes all versions of the card and averages the results.
A GTX 750 Ti as suggested above scores 3684, although you are unlikely to find these new anymore.
A GTX 1050 would be the modern equivalent and that scores 5198.
Edit:
One other note, the GTX 750 Ti or GTX 1050 would allow you to run high settings of the original version with some mods, or the special edition with low to medium settings. These are mid range cards in terms of performance and have 2 GB of video memory.
To install high res texture mods with original skyrim or meet the recommended settings with skyrim special edition, you would need a GeForce GTX 1060 or Radeon RX 470.
well i mean thank you for the additive information but one thing that doesnt make sense is my friend has the same card just a slightly stronger cpu with 2 more cores- amd fx-6300... and he gets above 60 on medium/ high.. also for me 30fps i know is okay for skyrim but i think it could also be frame times with the game
To compare with your friend you need to make sure you are running the same version with exactly the same settings including resolution, texture quality and anti-aliasing.
From benchmarks you should be able to consistently get 60 FPS with your graphics card on original skyrim at 1920x1080 res, medium detail with no anti-aliasing. Mods or special edition can significantly reduce this.
As for your CPU. I have a Core i5 760 with is slower than your CPU on the passmark benchmark. The game would hover between 50 FPS and 60 FPS, but I believe this was limited by the graphics card anyway with the mods and settings I had configured. I don't think your CPU is the issue.
The other thing you haven't mentioned is your operating system. If it is a 32-bit version you can only access 4 GB of RAM, which can be an issue. A different version of Windows or display drivers could also be a difference with your friends computer.
