Skyrim lag and skip in GTX 550 TI SLI HELP
chevchillios
7
Alright here is the problem; I have Skyrim acting weird it is as if it is set on fast forwarding also sometimes lags. The first cut scene in the game should normally be around 5 minutes but it is over in about 40 seconds. Now I searched everywhere even on here and I can't find out how ti fix it. Also doesn't help I can't Google worth crap. All help is appreciated here are my specs:
Windows 7 64-bit
AMD FX 8120 8-core processor
8GB DDR3 Ram Dual Channel
Asus GTX 550 TI SLI
All drviers are up to date.
Oh also when I start the game it puts it to High Quality graphics.
Disable sli and see if that changes anything. I used to have some weird issues with Skyrim and a pair of 460s (not the same one mind you) that disabling sli fixed. If it behaves the same with sli disabled I'd do a clean install of Skyrim. Save any game saves you might have, uninstall the game and then re-install it again.
