Skyrim Online Mod Problem
SkittleLauncher
I thought it'd be cool to try out this mod. But its only giving me troubles.
Heres how it went down:
I followed all the instructions listed at the below link
http://skyrim.ophelia-core.com/showthread.php?tid=177
Everything seemed to be going fine. I got the launcher that came up, with the list of servers, and I tried joining one to see if i installed it correctly. But it didnt work. According to Steam i was in game, but only for about 5 seconds. I tried numerous times but with the same result.
Then i tried to play singleplayer, but that refused to work as well! I got an error saying: "Failed to initialize renderer. Your display doesnt support the selected resolution. Please set a different resolution in Skyrims Launcher under "Display Settings." So i tried changing the resolution, but with the same result.
So i thought, maybe its something to do with all the mods that i have installed. So i backed up my mods, and re-downloaded Skyrim. I re-installed the Skyrim Online Mod, but still didnt work!
My system is more than capable of running it. My specs are listed below:
CPU - AMD FX-6100
RAM - 20GB
GPU - GeForce GTX 650 Ti
Operating System - Windows 8.1
This is slightly frustrating, but i really want to figure this out to play Skyrim with some friends. Ive always loved the idea of Multiplayer Skyrim.
Any help would be much appreciated. Thanks in advance.
I have some experience with the Fallout mod VaultMP and it had the same kind of errors the fact is that these Multiplayer mods are a work in progress and many times don't work very well. I would suggest checking the online forum for this item there may be some small changes you need to make or there may be somethings you need to do to get it running.
Have you successfully ran the game before modding it at all? That doesn't sound like an error that would be caused by any multiplayer modding. It sounds like a graphical error. Make sure your drivers are up to date of course and try running the game at various resolutions without anything modded. You may be having some graphics related problems and not the mod itself.
