Skyrim RealVision ENB crashes almost every 2 minutes, why? Built this PC just for Skyrim so please someone help. :(
Ferrariassassin
1,514
7
19,795
If i push escape as soon as my save gets done loading it does not crash but if i do not hit escape it will crash as soon as my guy loads. I have an R9-290 and it runs the game at a conatand 40FPS or 79 at very rare ocassions but not constant FPS at that high rate. I have Reserved memory set to 512MB and Videomemory size set to 10240MB. If i set my Video Memory to anything else on realvision enb the game will crash and not even open and i mean it can not be ANYTHING but 10240MB which is strange considering i only have 4096M of VRAM on my R9-290. I use Loot and the other program with the entally retarded name called tes5edit and my mods are all cleaned, the game looks so beautiful, i installed it perfectly, set everything to what it says exept iy seys to set stuff like imaxgrass to 7 but my Skyrim.ini does not have anything called imaxgrass or whatever its called. I just do not know why it crashes a lot while playing yet if i pause the game ith ESC it will stay on for 2 days.I do not think it is mods as tes5edit and loot says its 100% ok so i may have put the wrong Reserved memory or Video memory size but if i set it to anything else Skyrim breaks completely, please someone help i have no clue to what is happening 🙁
you should have your video memory set to your cards vram. otherwise it sounds like other mods have broken the game. do you get these crashes on a fresh beginning of the game walk through or only on one of your save game files. you can use a save game cleaner and see if that helps, but you really should have all your mods bashed, tagged, cleaned, and ordered. do you have memory management enabled in the enb? ive only used boris's original enb but your realvision is just a preset and should be the same, assuming it is fully updated to 0.264
http://enbdev.com/download_mod_tesskyrim.htm
