Hi All,
I recently put together a new build and it's been working great, the only glaring problem I have is that when the computer goes into sleep mode, it won't turn back on. Specifically, in sleep mode it goes quiet, when I click mouse/press a key then the fans start up, sounds as if it's working, but the display remains completely black, and mouse laser doesn't turn on.
My system is:
- Intel i5-2500K overclocked to 4.2GHz (via motherboard overclocking utility)
- ASrock Z68 Extreme4 Motherboard
- Corsair Force 3 60gb ssd
- Asus GTX 570
- Corsair TX M600 power supply
- Corsair Carbide series 400r case (if it makes a difference?)
Has anyone come across a problem like this before? If so I'd really appreciate any advice on what I can do.
Thanks!
Jakub
My system is:
- Asus GTX 570
Thanks!
Jakub
