Sleeved Cable Question?
xNightCaster
33
I've recently decided to build a Gaming PC rather than buying the next gen console. I have been spending months researching what parts I want and what will fit by budget, but I am confused because since i've decided to buy sleeved cables, i'm not sure that kits I am buying will give me all the required parts in order to power all my components.
Can someone clarify with me that these specific kits include all the mandatory parts?
Cable Kits:
http://www.corsair.com/en-us/professional-individually-sleeved-dc-cable-kit-type-3-generation-2-red
http://www.corsair.com/en-us/individually-sleeved-ax-860-760-atx-24pin-generation-2-red
Please check out my competed build and give me tips and suggestions as to what I should rather buy / do differently. >>> http://pcpartpicker.com/p/3OCFj
Thank You so much!
Build is perfect except the PSU.
Change the power supply:
Best 850w on the planet.
Sleeve kits here:
http://www.evga.com/Products/ProductList.aspx?type=10&family=Power+Supplies&chipset=+Power+Supply+Cable+Set+%28Individually+Sleeved%29
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($134.99 @ NCIX US)
Total: $134.99
(Generated by PCPartPicker 2014-05-21 23:34 EDT-0400)
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=377
Review ^
Yes the 2 cable packages you have chosen cover all the cables you need. You are going to have a ton of people tell you to do it differently or to choose this part over that. However, the build you have setup is a great build, but unless you are also going to be doing video rendering the i7 is overkill. An I5 cpu and a different mobo will be a better route and a little less expensive as well. The i5 3570k is a great cpu and can overclock to over what you need. A good mobo to go with it would be http://pcpartpicker.com/part/asrock-motherboard-z77performance and it still goes with your color scheme.
Yes I know i've been told multiple times that i7 processors have no performance difference in gaming as compared to i5 processors, but i've saved up a bit over the months and I want to build a computer consisting of higher end parts that fit my price goal (with rationality of course).
Thank You for your suggestion though.
