UnknownUser1022 Honorable Feb 20, 2013 81 0 10,640 Nov 30, 2015 #1 Anyone know a place I can find some sleeved SATA power extensions? Need an extension that has a straight female connector because the location for the drive makes the right angle connectors bend more than I like. Black or white is preferred. Thanks!
Solution Geekwad Nov 30, 2015 This place will custom sleeve anything for you: http://www.performance-pcs.com/sata-cables-231
Geekwad Admirable Sep 25, 2015 2,368 1 6,960 Nov 30, 2015 Solution #2 This place will custom sleeve anything for you: http://www.performance-pcs.com/sata-cables-231 Upvote 0 Downvote Solution
